audio code
Old Feb 4, 2013 | 12:52 PM
Flug45's Avatar
Default audio code
Hello, can anyone tell me what audio code is model sc-901 on my c70 vin number yv1nc62d44j046201. Just replaced battery and now it is locked. Thanks
Old Feb 5, 2013 | 07:44 AM
MSGTUSMC's Avatar
Look for a 4 digit number on the radio label or in your manual. The dealer can look it up for you. They are specific to your VIN.
Old Feb 10, 2013 | 02:00 PM
sergvillarreal's Avatar
Default audio code 9731?
I pulled the radio out today and the code on top says 9731. How does one enter a '9' and a '7' on a keypad that only goes to '6'? puzzled.... any ideas? I can wait till tomorrow to call the dealer, but I am still curious.
Old Feb 10, 2013 | 05:05 PM
That is not the code. Look in the General Forum, then the FAQ thread for radio code information.
Old Feb 11, 2013 | 03:40 AM
MSGTUSMC's Avatar
Anytime you disconnect the battery, the battery dies, you pull out and disconnect the radio, replace the radio, etc., you will get locked out of your stereo because of the security feature. To get the radio code for your car:
1. Look in your owners manual booklet. There is usually a white card in there with the 4 digit code on it.
2. Pull the radio out and see if it is written on the radio chassis.
3. Look in the (https://volvoforums.com/forum/volvo-850-16/cannot-start-radio-after-putting-new-battery-52074/) glove box. Some people stick in on the inside of the glove box door.
4. I actually write it on the passengers side sun visor mirror lid.
5. Contact your local dealer with your VIN. They may ask you to prove ownership. If your radio was changed they will need the radio model # and serial number off of the top of the radio (sticker).
6. If you don't have a local dealer, call Volvo Cars of North America with the VIN. 800-458-1552.
That should do it. Once you get it try to put it somewhere you can find it easy. I'd like to start the trend of writing it in the passenger side visor mirror flap. Write it there with a sharpie.
If you have failed the 3 tries to get it right and are now locked out, there are a few options.
1. Just drive around with the radio on until you get a new chance. I think it will take about 2 hours of driving time. It can be 20 minutes here, 30 minutes there, it will add up the time.
2. Turn the car on the accessory position "I" (not started) and leave the radio on for 2 hours. It will reset and give you another 3 tries. Some radios the position is run "II".
3. Look in the owners manual and follow those instructions. If you don't have the owners manual, you can get it here:
http://www.volvocars.com/us/top/yourvolvo/volvo-vehicle-information-library/Pages/default.aspx
NOTE: If your radio reads ERROR, it is likely because there is a cd stuck in the changer or in the deck. If that is the case, unplug the changer or get the disc out of the player. I had a CD changer with a broken gear tooth that stopped my changer from working.
That ought to do it.
PROVIDED BY RSPI not myself!
HERTANTO
Sep 30, 2008 07:28 PM
pam@picton.net
Aug 4, 2005 01:46 PM
Volvo240T
Jun 16, 2005 02:32 PM
pilot
Jun 21, 2004 07:25 PM
yng740gledriver
Oct 17, 2003 05:10 AM
