Brake Job. parts ordered
Old Mar 19, 2009 | 04:22 PM
ddub's Avatar
Default Brake Job. parts ordered
I ordered the Brembo/Akebono kit from FCPGroton and it should be here in a few days. Anything special to the remove/replace or can I just plan on a simple caliper removal/piston compress and replace?
Old Mar 20, 2009 | 08:53 PM
Simple you will need a 7MM allen to loosen the caliper screws.
Old Apr 13, 2009 | 02:46 PM
ddub's Avatar
Default Brake Question
Tech, Do the caliper pistons not need to be compressed with these calipers (front and rear). and is the "locator pin" noted in the VADIS an issue or is it just a light friction fit?
Also, do you happen to remember caliper screw torques and lugnut torque values?? TIA
Old Apr 13, 2009 | 03:18 PM
reg's Avatar
reg
I highly recommend that you flush all lines and calipers when you perform your brake job. You will need DOT 4 fluid.
r.
Old Apr 14, 2009 | 09:06 AM
ddub's Avatar
yeah.. gonna pay my local shop 50 bucks to do the messy work.. just not gonna pay them the big bills to change out the hardware..... Ive gotten picky about what Ill do myself in my old age... anyone got a word about having to compress the pistons?
Old Apr 14, 2009 | 04:29 PM
reg's Avatar
reg
You do not indicate what year c70 you own. If it is the first iteration then yes, the pistons need to be compressed. Do not forget to not only lube the calipers but also the pins. You should also spray a bit of CRC brake 'quiet' on the back of your pads. As to bleeding the system..........two items come to mind: first............you surely are not older than I................I perform that messy job, and second...........if indeed you do go to an independent shop MAKE SURE THE SHOP USES DOT 4 fluid.
r.
Old Apr 15, 2009 | 10:34 AM
ddub's Avatar
its a 2004.. tech said it was just a simple remove and replace.. the vadis I have says nothing about caliper compression for the caliper/pad change...
PaddyG
1998-2000 model year V70
Feb 17, 2014 05:23 PM
dads 740 turbo
Oct 2, 2008 01:05 PM
frankhenderson
Mar 10, 2008 10:57 AM
tomservo
Suspension
Sep 16, 2007 09:57 AM
PREDATOR
May 18, 2007 09:20 AM
