C70 Enginge Light On
Old Jun 7, 2006 | 06:09 PM
ChrisP's Avatar
Default C70 Enginge Light On
I have a C70 convertible (RHD) 2L Turbo delivered early 2001. I've got the Engine light on, does anyone know if I can easily read the code?
I did notice that there is what appears to be a few drips of water coming from just behind the right front wheel about 2 feet in when the car first starts, do you think that could be the problem and what might it be?
Thanks for you help.
Old Jun 7, 2006 | 09:01 PM
Default RE: C70 Enginge Light On
No easy way to pull codes you need to have either the Dealer or Someone with a good setup pull the codes.
Old Jun 21, 2006 | 02:42 PM
ChrisP's Avatar
I took it along to a dealer and he said it was a single oxygen sensor error, then reset it and charged me £32 for the privilege. I understand that if I have a frequent error it needs to be fixed, but if it happens every 6 months I’d like to reset it myself, do you know if I can somehow reset the alarm?
Ta.
Old Jun 21, 2006 | 08:52 PM
You will need to buy a scanner that reads engine codes on a 2001 car.
VolvoLover2011
Jun 25, 2014 08:32 AM
securisign
May 31, 2014 11:10 AM
GoVolvoParts
Nov 29, 2012 08:46 AM
ErnstlS90
Oct 23, 2008 08:37 AM
Soloracer
Oct 3, 2006 08:45 PM
