C70 Passenger electric Window
Old May 5, 2009 | 02:42 AM
ICE's Avatar
ICE
Default C70 Passenger electric Window
Take a look at this !!!!! I havent ever thought to post this up but when the switch was replaced it was put in incorrectly by the guy who had the car before me......what a num nuts.
I dont know how to swap it over, Ive undone one screw but it wont come out. do I have to take off the whole door ? are there some instructions for this badboy ?
Old May 5, 2009 | 06:04 PM
mkc70's Avatar
Should be the procedure.
http://www.volvo-forums.com/index.ph...c=17967&hl=diy
Old May 5, 2009 | 07:19 PM
ICE's Avatar
ICE
Originally Posted by mkc70
thanks chief ! ill give this a go .
Old May 5, 2009 | 08:41 PM
mkc70's Avatar
Even though that is the procedure to remove the panel, I can not remember if the switch is removable by itself without removing the panel. Been too long.
Old May 5, 2009 | 08:54 PM
Yes it can be removed without removing the door panel.
Old May 6, 2009 | 02:12 AM
ICE's Avatar
ICE
oh ? there is only that torx bit and i cant seem to pry it off
Old May 6, 2009 | 06:10 PM
I used a hook tool by the switch and hook it by the button and pull the switch assembly out.
Old May 6, 2009 | 06:40 PM
ICE's Avatar
ICE
ok so get something that will lift the button out....i just dont want to go pulling something and then having to buy a new window control.
Old May 6, 2009 | 07:19 PM
Go in behind the button you will not pull up on the button like closing the window you will pull on the plastic behind the button.
Old May 7, 2009 | 03:10 AM
ICE's Avatar
ICE
ok thanks Tech, ill give it a go, hopefully without breaking anything
Old May 12, 2009 | 06:05 AM
n559br's Avatar
You can get a nice set of hooked style picks at harbor freight. That is the tool for this job.
Old May 18, 2009 | 02:23 AM
ICE's Avatar
ICE
http://www.harborfreight.com/cpi/cta...emnumber=66836
this kind of thing ?
Old May 18, 2009 | 09:26 PM
Yes exactly!
Old Jul 7, 2009 | 10:56 PM
ICE's Avatar
ICE
OK so I have finally got around to it and this is the furthest i have got. I have tried down the side at the little black clips but they wont budge and I dont want to break it off. Will I have to take my whole door trim off to change this silly thing over....
Old Jul 8, 2009 | 06:42 PM
The entire section should have come out not just the cover.
Old Jul 8, 2009 | 08:07 PM
ICE's Avatar
ICE
f**k , looks like the door trim will have to come off then.....it didnt feel at all like it would budge Tech
Old Jul 9, 2009 | 01:03 AM
  #17
mkc70's Avatar
I would use a small flathead screwdriver or pocket knife on the clips on the end of the switches. Taking the panel off is easy though if necessary.
greenman86
Nov 16, 2014 08:57 AM
jipsy
Jan 22, 2012 06:00 PM
850GLTWAGON
Nov 21, 2008 04:14 PM
Beardog
Nov 3, 2007 02:52 AM
Long
Jun 7, 2007 02:57 PM
