Subwoofer addition
Old Feb 15, 2008 | 11:04 AM
PE**2's Avatar
Default Subwoofer addition
I would like to add the factory subwoofer kit to my 2001 C70 LPT Cabriolet.
I was informed by local dealer that the kits are no longer available.
I understand that the amplifier is an Alpine and the subwoofers were made by Dynaudio. If any one has the model numbers for these parts I would appreciate it. I guess I also need the rear seat shut off switch so the back seat passangers don't get a low frequency back massage.
Old Mar 1, 2008 | 04:17 PM
DJRUZERS6's Avatar
Default RE: Subwoofer addition
I have a 1999 C70 coupe and I recently installed a Kenwood 1000 amp and a single 12" subwoofer. your better of checking out different brands if you want to get good bass from your car. I recomend that you do not get any kits from the dealer bcause they are very expensive and give a very bad sound. I installed the whole system in about 4 hours. And it sounds great...
Old Mar 1, 2008 | 07:38 PM
Shaun Oriold1's Avatar
DJRUZERS6 did you add the your single sub in behind the rear seats? but you only did one? Did you add a shutoff switch like the factory used?
S.
Old Mar 2, 2008 | 07:33 AM
reg's Avatar
reg
Dynaudio speakers are the Rolls Royce of speakers! Do not be fooled that they are not. Your Volvo dealer has brochures on Dynaudio and you might want to go to Dynaudio's web site. It is nigh impossible to 'blow' one of their speakers unless you are a teeny bopper who is going for noise. The entire system (Dolby surround sound) is available used and perhaps you could find one on Ebay if not your local Eupopean salvage yard.
r.
Old Mar 2, 2008 | 12:48 PM
PE**2's Avatar
Reg
I have checking out Ebay, Euro Salvage and Dynaudio. What I really need is the DynAudio model numbers. The DynAudio website just lists there components without any application info. Same for the Alpine Subwoofer amplifier and crossover if any.
PE**2
Old Mar 2, 2008 | 01:24 PM
DJRUZERS6's Avatar
My C70 already came with the Dynaudio subwoofer system but the owner that had the vehicle before me said that he had to replace the system 3 times because it was either blowing the speaker or blowing the amp. So I removed the system and I placed my own. my kenwood amp has an input wire for ON and Off, whatI did was that I used the positive wire that goes to my car antena and I used it as myOn and Off. So every time that I turn on my radio, the amp turns on and the subwoofer is powered. I have the subwoofer dirrectly behind the right rear passenger seat, and my Kenwood amp aloows for 2 Subs, so I will be adding another one shortly.
Old Mar 2, 2008 | 02:29 PM
PE**2's Avatar
DJ
did you save the old componets? How did you remove the back seats? Where was the amp mounted? Thanx.
Old Mar 2, 2008 | 02:50 PM
DJRUZERS6's Avatar
The owner had them removed before I bought it, but as you know you need a positive wire to be run from the battery to the end of the car...i ran the cable threw the seat part or the sitting cushion..to remove that you need to pull up from the bottom of the seat on both sides and the seat comes off...you also need to remove part of the trunk carpet the goes near the back of the seat, so that you are able to pass the positive cable of the amp to the back (Nicely)... i placed the amp in front of the subwoofer and i placed the sub speaker on the far left back side of the trunk
Old Mar 2, 2008 | 03:30 PM
reg's Avatar
reg
My old c70 was purchased new in 01 and never have I had a problem with the radio. The Dolby Pro Logic Surround Sound is the best on the market...........bar none!! I have had the Bose in Audis, the Bose in Millenias, and the up scale in BMW and none of them hold a candle to the Volvo Pro Logic. That is one of the reasons that I have kept this auto. I Have 5 autos and this is the oldest...................and most prone to break downs.........but I simply love the styling and the interior (to include the radio).
r.
Old Mar 3, 2008 | 02:06 PM
DJRUZERS6's Avatar
fuse and positive wire running to trunk..
the rear seat before lifting
">Name:  car005.jpg
rear seat lifted
">Name:  car006.jpg
cable going threw the rear passenger to the trunk
pass the positive wire threw the back seat and into the right far hand side of the trunk
use the positive connection on the antena to turn the AMP On and Off whwnever the radio is On and Off
get the cables and place them all neatly and screw the amp only into the carpet material..
then place you sub in there and reset the ammoubnt of power you want from the AMP
Old Mar 3, 2008 | 03:47 PM
PE**2's Avatar
Default DynAudio Subwoofer addition
I am going to have to do a little more research as my C70 is the rag top version. I would like to find the DynAudio speakers that fit in the rear seat backs. Does any one have the DynAudio part numbers for these?
Old Mar 3, 2008 | 04:34 PM
DJRUZERS6's Avatar
Default RE: DynAudio Subwoofer addition
these should be the Dynaudio part number
S70 Kit: 9452163
V70 Kit: 9452164
i found these on this web page, i think there might be more..
http://www.jimrothe.com/volvo/volvo-dynaudio.html
Old Mar 3, 2008 | 04:40 PM
reg's Avatar
reg
I know this posting does not help or answer your issue but I just had the opportunity to hear the Mark Levinson stereo in a new Lexus 460 and it is without doubt the most exotic system I have ever heard!! I does put the Volvo surround sound to shame...............truly if the Mark Levinson is a 10......then the Volvo is a 6. It's that good! But continue with you subs
r.
Old Mar 3, 2008 | 04:46 PM
DJRUZERS6's Avatar
hey reg..i have herd this system my buddy has it in his car...and it sounds incredible...the sound quality thatsystem has is beyond the Volvo Dolby Sourround Sound..
Old Mar 3, 2008 | 06:16 PM
reg's Avatar
reg
It is incredible! You saw my earlier postings..........I have and have had quite a few high end european autos and up til now, I truly thought the Volvo system was the best by far. Looks like I'm going to have to get a Lexus now. Actually we have two Japanese vehicles.....one with the Bose system and the little MX-5 with just a 4 speaker basic radio.
r.
Old Jul 9, 2009 | 06:53 AM
markjel's Avatar
Default C70 Convertible Amplifier
Hi,
I've lost all bass from my sc-901 system, seems tobe the bottomw 2 door speakers stopped working.
I'm trying to find the amplifier to check the fuses but I can;t find it anywhere.
Can anyone tell me where the original amplifier is fitted on a 2001 C70 Cab?
Thanks,
mark
Old Jul 9, 2009 | 06:35 PM
  #17
mkc70's Avatar
r.
I agree the ML system sounds great, but it is far more the equipment and tuning. The speakers if seen outside the vehicle are pretty uninspiring.
Old Jul 9, 2009 | 08:52 PM
  #18
C70_Guy's Avatar
Well I have a 98 C70 Coupe and it has the Alpine 400-watt amp. Not sure if it's the same for Conv.
This is the part number : 3533798
Here it is on eBay.
http://cgi.ebay.com/ebaymotors/Volvo...lenotsupported
donf
Mar 17, 2012 12:34 PM
Pugluvr
May 2, 2011 11:10 AM
vieves40
Jun 17, 2010 03:23 PM
mstrplmber
Aug 28, 2008 03:34 PM
bne
Apr 10, 2008 02:46 PM
