C70 Stuck Passenger seat
Old Jul 10, 2011 | 02:50 AM
Latorg's Avatar
Default C70 Stuck Passenger seat
Hi
I have a 2007 right hand drive C70. The passenger seat (not motorised) is stuck in the forward position. I have tried using the normal levers and adjusters to realease it. I cannot see anything which could be jamming the rails. Neither can I see anything obvious to release it. It feels that the left side of the seat is free, but the right, nearest the driver appears jammed.
Old Jul 17, 2011 | 12:53 AM
JayP71's Avatar
Look for a missing spring under the seat. Often a spring or a cable will detach, preventing one side of seat from moving.
Also, if you can't find a spring, look for a small hole where there used to be one. When these break or come loose they can fly a pretty good distance away from where they went.
*Disclaimer: I have no idea how an '07 C70 seat adjuster looks. Basing my answer on a lot of aggravation earned with other makes and models.
sterling157
Jul 3, 2009 08:47 AM
d myers
May 8, 2009 09:59 PM
amotin
Dec 12, 2008 09:13 PM
pleonard
Nov 17, 2007 09:30 AM
hosey82
Aug 4, 2007 09:51 PM
