C70 timing belts and valves
Old Jul 10, 2023 | 06:26 PM
larrymotormon's Avatar
Default C70 timing belts and valves
On the C70's around 2000, is the timing still accomplished with belts instead of chains? If the belts wear out and break while driving, are the valves in danger of colliding with the tops of the pistons?
On what models and years did timing chains begin to be used? Thanks!
Old Jul 10, 2023 | 06:35 PM
Yes and yes. Timing belts are used on ALL the 5 cyl aluminum block engines. ( 1993-~2016 and the 4 and 6 cylinder variants)
They are all interference engines - if the belt breaks, or becomes misaligned - valves are bent.
The 3.2/3.0turbo 6cyl FoMoCO/Landrover/Volvo engines used in various Volvos (2006?-2016?) do not have a timing belt. The (2015+) later 4 cylinder direct injection engines do use a timing belt.
Old Oct 5, 2023 | 09:58 AM
bkinney's Avatar
I had my 2007 S60 with 42k miles timing belt and water pump changed because of age...when is the next change needed?
99volvo$80
Jul 23, 2016 09:03 PM
vampie85
Jun 16, 2016 12:50 AM
Crow
Aug 31, 2015 09:12 PM
capwheel
Mar 6, 2012 02:05 PM
razd001
Sep 12, 2011 12:00 PM
