Car slightly pause and jerk on the freeway
Old Jan 30, 2009 | 12:18 AM
kewlle's Avatar
Exclamation Car slightly pause and jerk on the freeway
Hi,
I want to say thank you in advance. Can someone help me please. I have a 2000 c70 convertible high turbo with 68k, Automatic. While driving on the freeway with a my foot on the gas to maintain speed at around 60-70 MPH, the car would pause for half a second and would jerk/accelerate slightly. It would happen every time the speed is constant.
I have a feeling that the engine is misfiring somewhere. The car accelerate fine if i press on the gas pedal. I wonder if I need to do a tune up since I did not have one yet and plus I have not change oil for the last 6k.
Please advice
Thank you
Old Jan 30, 2009 | 07:26 AM
Usually if it is misfiring the check engine light flashes when it is misfiring.
The turbo control valve might be bad as well.
Old Feb 2, 2009 | 04:22 PM
kewlle's Avatar
Tech,
Thank you for your advice. I want to know what do you think i should do next. So i took my car to a local mechanic shop. After scanning the car, the mechanic said there are a few error codes, transmission, etc, but it all aims to the speed sensor. He thinks I need to replace it but there is no guaranteed because his scanner is limited.
He suggests that if i want to narrow down the problem, I will need to take it to Volvo. Only Volvo scanner can detect it. It will cost me $130 to just have volvo run diagnositc. However, he said the speed sensor is only $100 and he can replace it for me to see if that will fix the problem.
Please advice. I will be waiting.
Thank you
Old Feb 2, 2009 | 09:26 PM
Is there any way you can get us the codes?
This way I can look into them more.
Old Feb 3, 2009 | 11:15 AM
kewlle's Avatar
Default Car slslightly pause and jerk on the freeway Reply to Thread
Tech,
The code are 722 1633 and 1618. Please advice.
Thank you
Old Feb 3, 2009 | 07:56 PM
Is the ABS light on?
Old Feb 3, 2009 | 09:04 PM
kewlle's Avatar
Default Car slightly pause and jerk on the freeway
Tech,
The ABS light is not on right now. However it was on 2 weeks ago, but I sent it into Victor, from a link in another thread. Other lights were on but went off after Victor rebuilt the ABS module for me, except the engine light.
The the car has been pausing and jerking/accelerating since there was a problem with the ABS module.
Please Advice.
Thanks
Old Feb 4, 2009 | 09:10 PM
Have the engine codes been cleared after the ABS was fixed?
Old Feb 5, 2009 | 10:41 AM
kewlle's Avatar
Default Car Slighly Pause and Jerk - please help
Tech,
No the engine light has never been clear since the ABS module is fixed.
Please advice.
Quan
Old Feb 5, 2009 | 08:37 PM
I wonder if the engine module is storing the code and setting it in the other module.
You might want to try to get them cleared.
Old Feb 7, 2009 | 05:26 PM
kewlle's Avatar
Tech.
I have the mechanic clear the engine light but the car still jerk/jolt when i keep steady speed on the freeway at 60-70mph (also at cruise control). From reading other post, do you think i should change spark plugs, etc and do the usual tune up? My car has 69k and I have not done any tune up yet.
Also from other post, some one had similar problem and they changed the crankshaft sensor and it fixed the problem.
Please advice
Thanks
Old Feb 7, 2009 | 06:54 PM
If you have never had a tune up I would start there.
Also another possibility is a bad turbo control valve.
keygrip_chris
Sep 13, 2024 09:46 AM
thecheat
Aug 21, 2010 11:07 PM
Frank_Minneapolis
Jun 25, 2009 07:11 PM
WagHag
Aug 20, 2007 05:29 PM
