Difficult doors
Old Mar 1, 2009 | 09:11 PM
SoDoWarts's Avatar
Default Difficult doors
The doors on my 2000 c70 with 71K are getting difficult to open. On the passenger side you'd swear that the door was locked unless you give it a real hard tug. I'm thinking that maybe with the weight of these doors cause this to happen over time. Is there some adjustment that can be made to help?
Old Mar 1, 2009 | 09:30 PM
Try a slight bit of lube. Also maybe the latches need to be adjusted.
Old Mar 1, 2009 | 09:36 PM
SoDoWarts's Avatar
Thanks. How are the latches adjusted?
Old Mar 1, 2009 | 10:30 PM
Try adjusting the latch on the body side.
Old Mar 2, 2009 | 04:46 PM
reg's Avatar
reg
If you have a coupe, you may find that the top of the window is making contact with the top of the door seal. IE: your windows need adjustment.
r.
Old Mar 3, 2009 | 04:13 PM
SoDoWarts's Avatar
I know what you are saying about the windows, but the doors are still difficult with the windows down.
Tech -- the bodyside latches are are screwed in (if I'm guessing right at what you mean). No means to adjust there.
Old Mar 3, 2009 | 08:09 PM
If you loosen them they will slide around a little.
DHC5tech
Mar 5, 2014 07:22 PM
Yachtman
Aug 8, 2006 12:32 AM
m1964
Jun 13, 2006 07:22 PM
spyder
Mar 18, 2006 12:36 AM
cgerdeman
Sep 10, 2005 01:54 PM
