Fuel Cap Stuck C70 2007
Old Jan 28, 2016 | 02:37 PM
Remik's Avatar
Default Fuel Cap Stuck C70 2007
Can anyone help? I am wondering if there is a manual release for the above car. It's a UK spec model. The release button on the dash has developed an intermittent fault. Any guidance would be appreciated.
Old Jan 28, 2016 | 07:25 PM
pkrface's Avatar
You should be able to peel back the trunk liner on that side and access the servo to manually move the plunger. The owners manual should have instructions.
Old Jan 29, 2016 | 07:50 AM
tryingbe's Avatar
Press the button on the light switch panel (see the illustration on page 55) with the ignition switched off to unlock the fuel filler door. Please note that the fuel filler door will remain unlocked until the vehicle begins to move forward. An audible click will be heard when the fuel filler door relocks.
Old Jan 31, 2016 | 02:07 PM
Remik's Avatar
Hi all, thanks for the replies, I am very grateful. I took another look at the issue today and found that if I removed the trim protecting the rear lights on the same side as the petrol cap and looked very carefully under the trim towards the direction of the petrol cap, there is a small piece of string which, when pulled, opens the cap. What a relief as I was running on fumes!!
Obelix
Jun 20, 2022 08:40 AM
dfilloux
2001-2013 model year V70
Jun 12, 2012 05:04 PM
JTJammer
May 12, 2011 10:31 PM
chandler
Mar 14, 2010 10:29 PM
amotin
Dec 12, 2008 09:13 PM
