fuel filter
Old Jul 4, 2006 | 05:00 PM
reg's Avatar
reg
Default fuel filter
TECH, I attempted to change the fuel filter on the c70...........following the instruction in the 850/c70 chilton's. The book calls for a 17mm open end wrench to release the fittings on either end of the filter. Not so on my c70! there are plastic caps surrounding the ends of the fuel lines and I have no idea on how to release them so as to change out the filter. Have you a suggestion?
Reg
Old Jul 4, 2006 | 08:13 PM
Default RE: fuel filter
Stick a pair of Needle nose pliers between the filter and the line and push the line off.
You might have to keep the nose of the pliers open a Hair to push the release in the line properly.
Old Jul 4, 2006 | 08:50 PM
reg's Avatar
reg
Ah ha!! So the line simply pull off either end. I can do that! Thanks a million TECH!!! I hope you are grilling some burgers tonight. It seems that I only put the charcoal on when a holiday is around! Yessir.............some potatoe salad, burgers, blue berry pie..........it doesn't get better than that!! Thanks again!
REG
Old Jul 5, 2006 | 12:40 AM
It was Steak, Grilled Potatoes,Corn on the Cob,and a few other things.
timoc663
Aug 14, 2016 05:35 PM
inilegna
Sep 25, 2013 03:27 PM
smithnr
Apr 8, 2013 04:56 PM
CoVoVo
Oct 24, 2012 10:19 PM
AnEskimo
May 15, 2011 12:32 AM
