Gear shifter stuck in neutral
Old Jun 5, 2020 | 04:48 PM
docnickashford's Avatar
Default Gear shifter stuck in neutral
My wife was backing out of driveway today and when shifting from reverse to drive the shifter became stuck in neutral. We tried the override technique used when stuck in park be inserting key and screwdriver in override slot in lower left of shifter panel and still stuck in neutral. Checked brake lights working normally and doesn't appear due to brake relay switch. Used onboard computer diagnostics and no codes came up. Open to any ideas/suggestions
Old May 16, 2021 | 04:03 PM
ses07's Avatar
Default Same problem, stuck in neutral and shift override not helping
hi, having this exact same problem at the moment. Did you ever figure out how to get out of neutral? Pushing down the shift override is not helping us
pnwskier
1998-2000 model year V70
Oct 6, 2016 05:22 PM
readvl
Apr 15, 2015 10:01 AM
martin 99 s80
Dec 3, 2009 03:26 PM
H20Gguy
Aug 15, 2009 12:15 PM
amotin
Dec 12, 2008 09:13 PM
