HELP dilemma
hi all just went to my car went to start and absolutly nothing! when i move the key to ignition all the service lights flash at me radidly when i go to turn the engine over absolutly nothing not a sound if i put the key just in the radio position the radio jus flashes at me cd changer/aeriel makes wirring noise and then nothing and to top things off i had to lock the car manually any one have a clue its just had its mot and am sure battery is fine its brand new
cheers
cheers
I would agree with TECH. It certainly sounds as though the battery is not up to par. When you do not have enough juice to raise the aerial and the dash lamps simply 'flutter', it is a sure sign of a discharged battery.
r.
r.
the mroe i think about it sounds like it havnt had car that long when i got it dealers said they had put a new battery in more likely they jus charged it up probably same battery been in it since came of production line its an 01 so ill jus buy a new battery and be done with it any recomendations? was looking at optima yellow tops but are pricey
Up here in Canada, we have Canadian tire. They will check your battery, and see if its crap or not. I assume the is a company that can do this service for you, wherever you are. It could be a bad ground as well. If your battery is good.
S.
S.
wb2alta
Feb 6, 2015 06:12 PM
