Hub and axle replacement video - knuckle / strut trick
Old Feb 7, 2019 | 11:09 AM
habbyguy's Avatar
Default Hub and axle replacement video - knuckle / strut trick
I just made a video of swapping out my right front axle and hub unit (I did both sides though). I couldn't find any other videos showing everything I wanted to see when I was searching, so I made one. This video is of my 2005 V50 2.4i, which should be the same as most S40s, as well as most C30s and C70s.
Some of the highlights:
1) A cool trick for getting the knuckle's clamp off your strut tower. A lot of folks struggle with this, but I show you a way to do it very quickly and very easily, and it doesn't even involve a hammer! ;-)
2) Pressing out the old hub and pressing the new on back in using a cheap 12-ton Harbor Freight press (just don't laugh at me when everything falls off the press when the hub clears the knuckle). ;-)
3) A quick visual comparison of the Cardone rebuilt (of an original Volvo axle) and the failed 4-month old Surtrack / Trackmotive axle (both of them developed rotational play in my case, within a few thousand miles)
The video can be found here: https://youtu.be/AekISXFTxfc
Old Feb 8, 2019 | 05:41 PM
habbyguy's Avatar
Sorry - the original video I uploaded didn't work....
habbyguy
Feb 9, 2019 10:22 AM
habbyguy
Volvo C30
Feb 8, 2019 05:39 PM
habbyguy
Feb 8, 2019 05:37 PM
rmurray
1998-2000 model year V70
Nov 11, 2013 09:55 AM
bobinyelm
Oct 27, 2010 10:45 PM
