I need a little help... Anyone ever had a door apart, or know anything about it ?
Problem:
I've got the drivers door apart on my 2000 C70, trying to figure out my window up/down issue. It would only go about halfway down, and then i would literally have to grab the glass and pull it up by hand, while pushing the switch in the up position.
Here's what I found:
The pulley system that operates the glass has one pulley, the one on the top/rear of the door that is all messed up, and the cable is off that pulley and is pulled tight in a downward angle.
I figured that it would be as easy as changing that pulley with a new one, and repositioning the cable to have a window that would go up and down the way it should... Well, Not that easy....
Question:
Is that brace that runs the length of the door at the top completely welded in place ? It looks as if the pulley is secured to that brace, and I dont see a way to get it out..
Question:
Any advice at all will be greatly appreciated.. Thanks !!
Problem:
Question:
Question:
crhawkeye
Jan 24, 2011 01:26 PM
diehardgator1
Sep 12, 2008 01:32 PM
Lab_Rodent
Dec 5, 2007 10:06 PM
