Inconsistent battery draw
Old Jan 9, 2015 | 07:23 PM
Therockf150's Avatar
Default Inconsistent battery draw
Greetings! I had posted in mid-November; I ended up purchasing a 1999 C70 for $400. It needs some work, but it runs and shifts fine- need to trace a possible coolant leak, do some brake work, etc... but it's really a steal at $400. It has the 2.3.
Bought a new battery for the car... previous owner had disconnected the stereo (it has the premium CD changer with external amp) because she thought that was draining the battery. I hooked up the new battery, and for several weeks didn't have any issues at all. One morning... battery was dead. After recharging it, it died again the next morning.
I hooked up a multimeter to look for a parasitic draw tonight and the car is drawing .04 amps... well within normal specs.
I DID notice a popping sound coming from the speakers when I went to start the car when I was having these battery drain issues. Has anyone run into an issue of the stereo causing a drain? It has the external amp in the trunk of the car as well.. could that be the problem? It's difficult to trace when it doesn't drain all the time!
Thanks for your help..
~Tom
Old Jan 11, 2015 | 12:46 AM
MSGTUSMC's Avatar
I would check all wiring/grounds etc. to installed amp. Disconnect amp power, see what battery draw is then. Good luck!
Old Jan 24, 2015 | 12:23 PM
Thanks! I haven't had the problem in awhile. I'm slowly working on getting the car on the road; I'm kind of hoping to locate a draw so it doesn't randomly die in the middle of nowhere.
davisrf
Jan 13, 2013 11:12 AM
dmkelly1955
Oct 27, 2010 01:36 AM
datderboy216
May 22, 2010 06:42 PM
EnzoRacing
Dec 26, 2009 01:03 PM
jdibber
Nov 13, 2009 07:36 PM
