Interested in a C70
So I sold my 94 850 Turbo and now need a new Volvo. I would love to get an 850R but good ones are hard to find. I am also interested in the high output C70. Can anyone give me some insight on what to watch out for with C70's? I am going to start seeing whats out there so any precautions are much appreciated. I am pretty knowledgeable with the 850's but C70's are new to me.
Things unique to the C70: Window regulators (expensive and challenging to repair or replace); Sunroof rattle (common); Broken micro switches in the front seats (seats are motorized); SC 900 / 901 Radio Cassette CD Changer (jammed CD players are common); Center Channel Pro Logic Dash Speaker - delightful in theory, but lead a hard life in the center of the dash and rarely work; Heater Cores (easy to change and will eventually fail); A/C evaporator (pain the a$$ to get to...some what invasive replacement); Lower control arms are different on the C70's; If you are looking at a convertible....then you can be on the look out for the common problems associated with a movable top. The rear back glass tends to eventually fall out of the top.
Other than that...it's a Volvo...Stage Zero maintenance is important.
If you are seriously considering purchasing a C70...I would think about parting with mine, so keep me in mind.
Good luck in your quest.
Ted
1998 C70 Coupe HPT - Manual Trans - Saffron Pearl
Cheers,
Ted
Good luck with your new purchase.
Cheers,
Ted
So today I took on the task of figuring out why my driver seat has no power. I started with the fuses, which checked fine. I then tried the switch board which worked fine on the passenger seat when I switched it over. I then swapped the main boards where it all connects to and that worked fine.... So i am left with the three Bosch seat motors as my culprit for causing the seat not to move at all. Luckily it is stuck in a tolerable position for me to drive in. I called the dealership and the motors go for $370 a pop! So i will be going to the junk yard in the near future. I am concerned that the c70 seat differs from s70s and 850s because of the side bar mechanism which was not on my 850. Too bad it was not a simple fix.
I see that you were parting out your other c70. Was that a black leather interior?
Does the seat move with the seat buttons? Does it move when you lift up on the lever on the side of the seat? The micro-switch that allows the seat to move for + aft is inside the pivot point of the seat, if it isn't working the seat won't move electrically. My passenger side did this. Cost me $1,000 for the dealer to replace. A problem with these seats. Just some info, don't know if it applies.
1998 C70 2.3 HPT Coupe Auto 37k miles
Sadly, I can't be of much help.
Let us know what you are able to figure out.
Cheers,
Ted H.
HelgaTheS80
03-15-2007 02:50 AM
vjules
06-02-2006 12:52 AM
jlevi
11-21-2005 05:59 PM
