Multiple trouble codes
Old Sep 30, 2009 | 06:06 PM
ckevg's Avatar
Default Multiple trouble codes
Here are my codes. I'm interpreting this as my problems are caused by a bad MAF and front O2 sensor:
0134
0171
0300
0650
1171
1174
I am the one that had the "missing" CEL bulb. Background: The car was running poor and I cleaned the MAF and she ran fine, no codes. Then about a week later (approx 300miles) she started the having same symptoms, that got worse the next time I started her. I have not driven her since because of the lean readings.
Old Sep 30, 2009 | 07:11 PM
Check for Vacuum leaks.
Old Sep 30, 2009 | 08:56 PM
ckevg's Avatar
Think that's all it is? Where can I get a vacuum diagram?
Old Oct 2, 2009 | 06:28 PM
There should be one on the hood.
You can also spray carb clean around all hoses with the car running. If the idle changes there is a leak.
Old Mar 19, 2010 | 08:30 PM
ckevg's Avatar
*update* Car has just been pretty much sitting in my driveway. No vacuum leaks. Should I start with replacing the O2 sensor?
Old Mar 19, 2010 | 08:45 PM
You might want to start with a MAF first.
keimini
Oct 12, 2009 11:22 PM
Old Blue 66
Sep 23, 2009 04:34 PM
Limon
Apr 6, 2009 08:08 PM
charlesd
Jun 25, 2008 06:47 PM
bluetank
Nov 2, 2006 10:21 PM
