No high beams
Old Dec 30, 2009 | 07:15 PM
dljdad's Avatar
Default No high beams
My wife's 1999 C70's headlights got stuck on high beam. She turned the headlight switch to daytime lights and back and tried again. It went to low beam and now won't switch at all. Stays on low beam. I've played with the headlight switch, making sure it is in the headlight position. When I hold the lever back it switches to high beam as long as I hold it but the fog/driving lights don't go off. I'm kinda leaning towards the headlight switch itself...but really don't know. It IS in the headlight position so the easy fix is out. Any ideas?
Dave
Old Jan 1, 2010 | 12:47 PM
dljdad's Avatar
I'd really appreciate some thoughts here. Does the headlight relay in the fusebox have a high beam/low beam section or does it control everything and there is a high/low relay elsewhere?
Old Jan 4, 2010 | 05:39 PM
mkc70's Avatar
Do you have the newer style headlight switch on dash? Should have a small green light on it if you do.
98isb360
Oct 13, 2021 08:47 AM
bkhan145
Mar 16, 2019 02:22 PM
m1964
Mar 14, 2006 10:56 PM
SilentBob
Oct 1, 2005 05:42 PM
Volvos since 1964
Feb 7, 2005 10:55 AM
