oil leak
Old Aug 9, 2015 | 05:45 AM
Martin Hinchcliffe's Avatar
Default oil leak
Hi all, recently had the head gasket replaced by a local garage. On collecting the car I was told it had developed an oil leak from the new gasket near the turbo. He explained that he suspected that the block must have been warped as well as the head (which was skimmed and pressure tested !) He also said that it only leaked a small amount when you turned the engine off. The next day there was a 12 " diameter stain on my drive. So its a bad leak and it appears to be leaking all the time. I would appreciate any help to identify what the problem may be. I intend to take the car back tomorrow as we can't use it as it is. Surely its the garages responsibility to fix the leak ! It didn't leak when it went in !
Last edited by Martin Hinchcliffe; Aug 9, 2015 at 05:49 AM. Reason: spelling mistake
Old Aug 9, 2015 | 08:37 AM
ES6T's Avatar
It is their responsibility to check the block and head. But if it didn't overheat, I doubt it's warped. They messed something up.
Old Aug 10, 2015 | 08:52 AM
MSGTUSMC's Avatar
Default oil leak C70
Might be a case "you get what you pay for". Always good to do some research on a shop before you have work like this done. I would not have accepted the car or paid for the repair, until the oil leak was fixed. Hopefully the shop fixes the problem at no cost to the car owner. In USA disputes can be resolved by the BBB. Been there, done that. Good luck !
Old Aug 10, 2015 | 09:38 AM
common leak cause is the turbo oil return line which runs from the turbo back to the block. Seems plausible to me they could have messed up its fit into the block or didn't do the cam (rear) seal correctly. there's also the roll on gasket which could have been incorrectly done for the upper head. Here's a great tutorial to see what's involved
Replacing The Head Gasket On A Volvo 850
Old Aug 10, 2015 | 12:51 PM
Default C70 Oil Leak
Thanks ES6T. It transpires it had overheated and he did check the block for straightness but with a straightedge !!
Old Aug 10, 2015 | 12:56 PM
Thank you. He was recommended by a very good friend who has a fleet of 7 vehicles maintained by him. I had no reason to question his authenticity. He has been to collect the car today to investigate further. Watch this space
Old Aug 10, 2015 | 01:01 PM
Thank you, I will advise him to check that area. Very frustrating when you can't investigate things due to lack of access or equipment !
Old Aug 11, 2015 | 02:52 AM
MSGTUSMC's Avatar
Excellent ! Could be a good mechanic with a honest over site .
ROBLU540
Feb 20, 2009 07:59 PM
mkelly85
Jan 31, 2008 02:05 AM
pleonard
Jan 7, 2008 06:12 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
