Rear window gasket
Old Aug 24, 2008 | 01:23 PM
OME's Avatar
OME
Default Rear window gasket
As anyone encountered this problem 2002 C70 rear window seal/gasket is deteriorating. Is this an eazy fix?
Old Aug 24, 2008 | 02:10 PM
Default RE: Rear window gasket
Usually only a new top will fix it. The glass is glued in.
Old Aug 25, 2008 | 01:03 PM
OME's Avatar
OME
I called the local dealership'sparts department to get a price check. The seal is running a little over $700.00 and is not in stock. Just my luck. Is this part something I can replace myself?
Old Aug 25, 2008 | 09:22 PM
Sorry not sure never did one. Last time I knew you only could replace the top.
jagtoes
Jun 3, 2014 10:34 PM
GrantRobertson
Jul 2, 2013 01:49 AM
Jetstreamer
Jun 14, 2012 09:32 PM
steved
Dec 20, 2008 05:37 PM
850GLTWAGON
Nov 21, 2008 04:14 PM
