Removing passenger door panel
When rolling up the passenger side window yesterday, there was some pressure and something snapped. The window will no longer roll up nor down. I'd like to remove the door panel to take a look but it's very tight. What is the procedure for removing/replacing the door panel? Thanks for your help on this project.
1ST I will bet the regulator broke.(PITA EXPENSIVE AND HARD TO REPLACE)
Remove the Clips around the bottom of the door panel.
Then remove the cover and the T-25 screw.
Then remove the Grey cover on the inside portion of the mirror.
In the small cuddy in the door panel remove the rubber mat in the bottom and you will see a hole. Insert a small screwdriver and pull out on the bottom of the door panel.
Then it should slide up and off.
NOTE:When you go to install it look inside where it sits on the top edge.You will see a little rubber strip inside the molding. Remove and slide that onto the metal on the door before installing the door panel.
xxscorpion
Jan 17, 2014 10:59 AM
