Roof liner glue?
The second panel from the front came unglued today. Looks like about 8 pads where the roof panel is glued to the top. What is the best glue to use, and the procedure on re attaching the panel to the top? 09 C70...
I was going to try some Hot Glue, but I ended up going to PepBoys and getting some plastic body panel push clips by Dorman. Drilled a 5/16 hole (very carefully and in reverse mode) in the headliner where the old tabs were. Pushed the clips through and gently tapping them into the roof panel holes with a small rubber hammer. Going to get some tan paint and paint them. Problem solved. Cost, less than $10
hovonogila
May 16, 2019 02:28 AM
rspi
Mar 3, 2014 10:39 AM
rspi
Feb 23, 2014 11:02 PM
