Some C70 Questions
Old Jul 7, 2006 | 12:08 PM
snulma1's Avatar
Default Some C70 Questions
Hey guys, just took delivery of my 99 C70 and I LOVE IT!!!! However I have some questions that maybe you can help me with!
1. The CEL came on, and when I took it to Autozone to have them read the codes, it came up P1171 which was Manufacturer Controlled Fuel & Air Metering. Which I was told is the Mass Air Flow sensor. But when I questioned a service guy @ Volvo about it. They said that if it was the MAF sensor, that my car would stall. And it doesn't. Is it possible that it was a single fault and now is operating fine? And if so, how can I reset the CEL?
2. The Service light has come on. How do I reset that one as well?
3. The car starts and runs beautifully. However, when I shut the engine down, it kinda shuts down roughly. Is that a problem with something? Or is that just normal for a 99 with 65K on it?
Thanks for your help guys
Old Jul 7, 2006 | 03:51 PM
reg's Avatar
reg
Default RE: Some C70 Questions
I had the MAF replaced in my c70 when the 'light' illuminated. I was not experiencing any driveability issues what so ever. Perhaps a cleaning of it with the new MAF cleaner that is now on the market may clean up the wire??
r.
Old Jul 7, 2006 | 08:16 PM
snulma1's Avatar
I unplugged the connection to the MAF and then took the negative lead off the battery for over 1 min. When I reconnected the battery the CEL stayed off. And hasn't come back on with 30 min of driving. So hopefully it was just a single fault. So now I can get it inspected. But does anyone know how to stop the service light from coming on?
Old Jul 7, 2006 | 10:30 PM
Do a search for "Service light reset" It is the same as the S40,S60,S80 and V70 2001 and newer.
Old Jul 9, 2006 | 08:58 PM
snulma1's Avatar
Ok, well the CEL came back on. And I think its the same fault. Which was P1171. Has anyone gotten the same fault? If so what did they do to fix it?
Also, what size tires are stock on a 99 C70. I think the tires are too big on mine, because when I cut the wheel all the way, it rubs on the wheel well. And i'm pretty sure that it shouldn't do that.
Old Jul 9, 2006 | 09:54 PM
I think P1171 might be the Cam sensor.
Any problems with stalling or not starting?
For the tire size check in the fuel door it should say on the sticker.
Old Jul 9, 2006 | 11:47 PM
snulma1's Avatar
ORIGINAL: tech
Well on the OBD II code reader @ Autozone, it said that it was a Manufacturers Air & Fuel Metering fault. Which I thought was the Mass Air Flow sensor. But when they looked the code up in the computer @ Autozone, it came out as a Rotor fault. Any ideas on that???
Old Jul 9, 2006 | 11:59 PM
I will have to try to look at the Cross refrence tomorrow at work and see what it is in a Volvo code.
Then I can help you a little more.
Old Jul 10, 2006 | 12:23 AM
snulma1's Avatar
ORIGINAL: tech
Thanks Tech, Ur a Life saver!
Old Jul 11, 2006 | 04:06 PM
snulma1's Avatar
Hey Tech, any word on the cross referencing of that P1171 code?
Old Jul 11, 2006 | 09:43 PM
Sorry been runnning my butt off trying to find a Cross refrence for it.
My computers don't even show 1171 as a code.
I knew that last nigth but forgot what post it was in.
Sorry I didn't get back sooner.
I am still trying to find it out.
Old Jul 12, 2006 | 03:05 AM
snulma1's Avatar
If I remember it was a P Code, P1171. And from what I searched online. I found most people replaced their MAF and it went away. But I'd rather not spend over 100 for something that I'm not sure what it is. So when it happens again, I'm out another 100.
Lansdowne
Sep 22, 2014 01:02 AM
Phil 850
Jul 25, 2012 10:01 PM
jderosa3
Mar 20, 2011 03:01 PM
B1mmer
Dec 18, 2006 11:24 PM
