Speakers
Old Dec 12, 2007 | 04:45 PM
Torkk's Avatar
Default Speakers
Anyone know what the speaker size are in the 01 c70. I searched and nothing to be found anywhere
Old Dec 12, 2007 | 04:54 PM
Shaun Oriold1's Avatar
Default RE: Speakers
Which speaker size are you wondering about?
you can try this topic https://volvoforums.com/m_52913/tm.htm it might answer some questions you have.
S.
Old Dec 12, 2007 | 07:10 PM
Torkk's Avatar
all the speakers and your link just brings me back to the main forum page
Old Dec 12, 2007 | 07:50 PM
My bad. I used the search function, and must have grabbed the wrong link. There is lots in past topics.
I'm going form memory. So dont quote me on it. try the search though
8" in the lower doors,
4" in the upper doors.
8" in the back.
4" in the dash.
I sadly dont have the ones in the subs rear seats. but I think those are 8" or 10"
S.
Old Dec 12, 2007 | 08:25 PM
Torkk's Avatar
thanx thats good start. I think i have components in the rear deck. I dont have center channel on dash just 2 front tweets.
But its something to work with I might look into upgrading the speakers at some point .
Old Dec 12, 2007 | 08:35 PM
I was reading the owners manual. I gather if you dont have the centre dash ( I dont) then you dont hae the upgraded system. in the owners manual it says that the speakers in the rear seats have a shut off switch in the rear middle consol. ( thats where the window switches are for my convert) I would gather if you have the shut off switch, you have the speakers. Therefor if you dont have the switch.. well you can figure out the rest....
S.
Old Dec 12, 2007 | 09:00 PM
Torkk's Avatar
ORIGINAL: Shaun Oriold1
S.
Rear middle console. Like where the opening is thru the trunk for long stuff to pass thru?
I know my rears are Dynaudio. the others not sure of. I did some surfing and found the sizes. Its listing the dolby suround system but the size are the same
In the rear of the car, you have
two 8-inch bass speakers and two 1-inch tweeters. In each door, there is
an 8-inch bass speaker and a 4-inch speaker for midrange. There are also
two 1-inch tweeters in the dashboard.
so you were about right
edit, I didnt see any info in the manual for that. I doubt I have the subs, the HU is 816
Old Dec 12, 2007 | 10:02 PM
PANTYEATR's Avatar
hey, heres a cool write-up on the upgrade process to the dynaudio sound system. very informative.
http://www.jimrothe.com/volvo/volvo-dynaudio.html
Old Dec 13, 2007 | 09:52 AM
reg's Avatar
reg
c70's come with dynaudio speakers. The quoted article was relevant to the s and v 70 along with the 'cheaper' head unit. One truly cannot obtain better sound than from the c70 stock unit with the Dolby Prologic Surround sound system!
r.
Old Dec 13, 2007 | 04:45 PM
JimKW's Avatar
One should never say you can not get a better sound system. No matter how good it is, you can always get better. That being said, I think the sound sytem in the C70 with the upgraded system is the best factory system I have every heard. I'm looking to upgrade the speakers in my 97 850 R, but not sure which way I am going yet. I really like to stick with the OEM stuff because I have this tendency to go way overboard once I strart buying audio systems. You should see my home theatre system.
Old Dec 13, 2007 | 05:12 PM
ORIGINAL: JimKW
Reg did say you cant get better sound out of your factory stereo. Your right. you can always get better. I just spent $800 of new speakers, since some were blown, but my sound is worse! [sm=WTFsgign.gif] I've since learned that when volvo makes the car, they program the factory HU to work in optimum with the factory speakers. In my case now that I've switched my speakers. My HU still thinks they are factory. Hence the poor sound. I'm told that if I upgrade my HU I can get better then factory. But Reg is correct. the factory HU, and factory speakers in a primo combo. If it aint broke dont fix it.
S.
Old Dec 13, 2007 | 05:42 PM
Torkk's Avatar
I have the 816 and thinking of getting the 901. Not sure about it thou, I dont have the DObly setup. As far as speakers goes they sound ok atm. Theres some farting out the rear deck speakers if the song is bass heavy, but over its pretty good. Once I get back on my feet im going to look around for replacement HU and drivers.I would like to stay with factory HU for the looks. I might add my sub box, not sure its a massive 2x12 or 2x10 JL Audio with a 300watt Memphis Audio amp.
Old Dec 14, 2007 | 06:05 PM
PANTYEATR's Avatar
in the link i posted the guy said that the 901 HU is made by pioneer? and that it doesn't have the internal amplifier like the 816 HU, so your gonna have to get the external factory amp for it to work properly.
so, all C70s come with dynaudio speakers? so the only difference in the premium system is that some use the 816 hu and some use the 901?
my front center speakes and rear passenger side speaker is not working, so i have to see if its the HU not putting out a signal or if the speakers are blown, but i would love to upgrade to the 901 HU.
Old Dec 15, 2007 | 10:35 AM
reg's Avatar
reg
Dynaudio are on par with Beovox...................you simply cannot obtain better speakers. Certainly Alpine and the rest are fine but what you must realize is that all speaker manufactures have several lines of speakers. In addition the speaker enclosure, and amplifier makes a difference but to simply diss Dynaudio as not being "the best" is obtuse. One might want to visit their local Volvo dealership and obtain the brochure that is available that visits the subject of Volvo's Dynaudio speaker system...........it is quite interesting!
r.
Old Dec 15, 2007 | 02:40 PM
Torkk's Avatar
my 01 C70 sounds pretty damn good with the Dynaudio even thou 1 dash speaker is out. Im so hoping thats its covered under the warranty. There is some bass fart if the song is bass heavy and its loud.
I really would like to change the 816 to the 901. But Im unsure if I would need the center speaker with it. I dont have that setup. I think I read that with Dolby Suround most of the vocals go thru the center channel. That and the 901's are a bitch to find
Old Dec 15, 2007 | 05:45 PM
PANTYEATR's Avatar
when you talk to your volvo dealer agian ask them if they can get you a refurbished 901 and if they will accept your old 816 as a core like the dude did in the link i posted. he said that he paid over all like $100+ for the reman 901 by doing that. don't forget that you'll also need that external factory amp with the 901 HU.
i need a center speaker and the housing since the the ******* who owned it before me broke and blowneverything. it could be possible that the center is justnot connecter, but i have to figure out how to getthe dash area apart to investigate [&:]
Old Dec 15, 2007 | 06:01 PM
  #17
You can always try this guy. He has about 100 scrap volvos at any given time. MAke sure to tell him you want one from the scrap yard, and not a new one though.
Its two brothers who both must be 100 years old. So you need to call them, no chance of email.
Hamiltons Garage.
1354 Gordon St
Guelph ON, N1L 1C8
CANADA
Phone: 519-822-3297
Fax: 519-822-3261
S.
Old Dec 15, 2007 | 06:08 PM
  #18
PANTYEATR's Avatar
dang! any cool connects that are in the country? LOL
the shipping takes forever outside the US and it costs way more.
Old Dec 15, 2007 | 06:17 PM
  #19
It is is MY country. Also about 45 minutes from my house. So shipping is never a problem....
S.
Old Dec 15, 2007 | 06:22 PM
  #20
PANTYEATR's Avatar
LMAO!!! wow thats funny bro. you should put that under your advatar, so we know next timeHA!
