Transmission stuck in same gear.
Old Jul 19, 2006 | 07:22 PM
atikovi's Avatar
Default Transmission stuck in same gear.
I went to see a repo 98 C70 with 168k miles at a local bank that was selling it cheap. It was very clean inside and out but the upshift arrow was blinking and it only had third gear. Is this a problem that probably requires a new transmission or could it be just an electrical control glitch? If I disconnected the battery to "reset" the computer would that do anything?
Old Jul 19, 2006 | 10:01 PM
Default RE: Transmission stuck in same gear.
Have the codes pulled and Cleared. It could be something very simple.
Anytime the Trans computer see a fault it goes into Limpo home mode.(What you see only 3rd Gear or always start in 3rd then changes to 4th after driving.
Old Aug 16, 2006 | 07:58 PM
atikovi's Avatar
Can my generic OBDII scanner get those codes?
Old Aug 16, 2006 | 09:10 PM
Some can and some Can't does it read Transmission codes?
Old Aug 16, 2006 | 09:44 PM
atikovi's Avatar
I got it when OBDII just came out 10 years ago so probably not.
Old Aug 17, 2006 | 08:41 PM
Maybe Auto Zone can if you live close to one.
Old Aug 17, 2006 | 09:16 PM
atikovi's Avatar
I was able to get codes P1618 and P758 which relates to shift solenoid B electical circuit. How hard will it be to access the shift solenoid. The manual says among other things to drop the subframe. Looks like a real PITA.
Old Aug 17, 2006 | 09:36 PM
Yes it is a Pain Clear the codes and see how fast they come back.
Old Aug 17, 2006 | 10:19 PM
atikovi's Avatar
The codes come back instantly.
Old Aug 18, 2006 | 12:45 AM
I will have to try doing some checking.
Usually it will take a little bit to come back. But instantly maybe a wiring problem.
Obelix
Jun 20, 2022 08:40 AM
SJanas0993
Feb 22, 2011 05:11 PM
amotin
Dec 12, 2008 09:13 PM
gratefulvolvo
Jan 3, 2008 08:28 PM
Lucy
Oct 1, 2006 08:52 PM
