Vac question
Old Feb 18, 2010 | 08:53 AM
Mooman333's Avatar
Default Vac question
If you had a vaccum leak that was enough to cause loss of gas milage or throw CEL, would you be able to notice a change with the readings on a vac/boost guage?
Old Feb 18, 2010 | 09:16 AM
mkc70's Avatar
Yes, the variance from stock boost levels would show , but it would not tell you where the leak or leaks are at. Your 2000 should under go a full stage 0 check. This would include inspecting all your vacuum lines, or as many would recommend just changing them out if they are original. Silicone vacuum hose is a popular replacement which I did on mine shortly after buying it.
Old Feb 18, 2010 | 09:29 AM
S70driver's Avatar
You should be running 15-20 In Hg on your vac/boost gauge stock. So if it is lower then then 10 you got an issue.
Old Feb 18, 2010 | 02:12 PM
Mooman333's Avatar
Default Second question
Thanks guys... Ok so another question then. What are the vaccume lines used for in this vehicle and how do all of these systems still function the same when it is not under vac but under a 12psi boost during acceleration? Manual trans mind you...
Old Feb 19, 2010 | 09:37 AM
mkc70's Avatar
Here's a video that may help.
http://www.ipdusa.com/product.asp?st...hStartRecord=1
ENDEE666
Jan 29, 2024 01:33 PM
ENDEE666
Nov 23, 2006 10:10 PM
kman3786osu
Oct 22, 2006 10:12 PM
S70driver
Apr 22, 2006 03:45 PM
