Volvo C70 transmission flush
Old May 5, 2017 | 11:52 AM
xerxes66's Avatar
Default Volvo C70 transmission flush
I have an opportunity to buy a 1999 C70 convertible that was flooded
Oil was changed - there was some H2O in it
I know I have to change the trans fluid
Any guidelines on this ?
Any warnings?
Am I crazy to consider this car (it's one owner - 100 K & it's cheap!)
Thanks in advance!
Old May 20, 2017 | 08:20 PM
Blade's Avatar
With any flooded car there could be really any kind of unpredictable problems, most likely most electrical components will have to be replaced (if flooded). These cars are really nice but honestly I would not consider this one as you can find a decent running one for a reasonable price.
Old May 20, 2017 | 10:46 PM
Considering the concern over contamination you'd want to do a transmission flush, not a drain and fill. The process is essentially drain the pan then reinstall the plug. Open the line to the transmission oil cooler and fix a clear hose on it going to a bucket with volume measurements. fill the tranmission with an equal amount you drained. Start the car, and idle until the hose shows air, then turn off the car and refill the transmission (should be like 2 quarts each time). repeat until the fluid coming out is new. refill then check the level both cold and warm (after some drive time).
Should take about 12 quarts. The most important tip is to use the correct fluid type per the owners manual (ie if it says JWS 3309, don't use Dex III/Mercon etc).
patrm
2001-2013 model year V70
23
Mar 5, 2014 08:43 PM
Count Chocula
May 3, 2012 05:28 PM
shop2
Nov 1, 2011 08:56 AM
onetwothreetim
May 6, 2011 04:09 PM
Glenn B
Feb 19, 2008 04:57 PM
