Wanted Used Volvo Parts
Old Oct 5, 2004 | 05:33 PM
Rinse's Avatar
Default Wanted Used Volvo Parts
I am looking for a Window Regulator for my 1998 C70.....please help
Old Jul 6, 2006 | 04:38 AM
rjpalmdesert's Avatar
Default RE: Wanted Used Volvo Parts
this place may have one, I need one as well... ;p
http://www.erievovo.com/
good luck, Rick
Old Jul 6, 2006 | 09:21 PM
reg's Avatar
reg
Take a ton of $'s with you as the regulator is costly. I had the door panels taken off from my c70 and had the regulator lubed with motor cycle chain lube as a preventative measure. Something for you to think about on the remaining 'good' regulator.
Reg
Old Aug 7, 2006 | 03:23 AM
FernC70's Avatar
What does that do??
Old Aug 7, 2006 | 04:26 PM
c70_joe's Avatar
ask your local breakers yard or try ebay/volvo sites i know new there about $100 so could probly get one second hand foraround $50
Old Aug 7, 2006 | 07:15 PM
reg's Avatar
reg
frees up the pullys that bind up. When that occurs the regulators go kaput. You can do the job yourself if you have a 1/2 hour per side.........I just do not have the time. Cycle chain lube has synthetic properties and the lube will adhere to the moving parts unlike white lube that is normally used on door hinges and the like. I use chain lube in lieu of any other type.
Reg.
ORIGINAL: FernC70
What does that do??
cobby
Nov 11, 2013 01:49 PM
eriknorcal
Jul 12, 2013 11:24 PM
AldenX
Aug 15, 2012 03:13 PM
beefheart
Oct 20, 2011 08:52 PM
islandmanpa
Oct 21, 2006 12:57 PM
