What size rear spacer on 1998 coupe
Old May 18, 2012 | 07:06 AM
tuner4life's Avatar
Default What size rear spacer on 1998 coupe
I was reading through the owners manual on my 1998 c70 coupe, is says that the rear track is only a couple mm narrower than the front, It seems really hard to believe considering how sunk in the rear wheels look.
My question is, what size spacers are you guys running on the rear? I have a hookup on a set of 15mm eibachs w/ extended bolts. Is 15mm enough to make the rear look even with the fronts? I am running 1998 v70r wheels.
Also post a pic or 2 of your car with spacers and say what size they are. Thanks.
Old May 21, 2012 | 09:01 AM
tuner4life's Avatar
60 views, and nobody has any idea... C70 section is real active I see.
Suppose Ill have a guess at it.. 15mm eibach spacers ordered for the rear, if needed I'll order a set of 5mm for the front.
Old May 22, 2012 | 06:18 PM
MSGTUSMC's Avatar
http://www.matthewsvolvosite.com/for...spacer#p172716
Good forum site for additional info!
boldtu
Jun 20, 2010 08:46 PM
N1ne
Sep 20, 2009 08:18 AM
cdurnal
Dec 7, 2008 11:09 AM
cdurnal
Oct 28, 2008 06:45 AM
shuvav
Oct 7, 2007 07:10 PM
