recommended spacer size
Old Sep 19, 2009 | 10:31 PM
N1ne's Avatar
Default recommended spacer size
I have the same problem as a lot of guys that have either changed rims or tire on there S60 and i am looking for what spacer size to use to stop this rubbing? I am running 17" rims with a +48mm offset .Is a 5mm spacer to small to help this problem?If yes am i going to see any issues useing a 15+mm-25mm spacer even if i use longer lug bolts?
Old Sep 20, 2009 | 03:41 AM
twowheelin's Avatar
I had some slight rubbing with 17" Pegs at almost/full lock. I just installed some 5mm spacers today and it sounds like my rubbing issues are corrected. I wanted to go with the minimum to reduce alignment issues. The rub was occurring on the inside front of the fender well at about the 10:00 position with Eibach springs.
Old Sep 20, 2009 | 08:18 AM
Instead of buying spacers unscrew the steering stops in the control arms. Then put 2 washers behind the stop on each screw on each side that should stop the rubbing.
tuner4life
May 22, 2012 06:18 PM
boldtu
Jun 20, 2010 08:46 PM
cdurnal
Dec 7, 2008 11:09 AM
cdurnal
Oct 28, 2008 06:45 AM
shuvav
Oct 7, 2007 07:10 PM
