Wheel Bearing Job
Old Apr 15, 2009 | 12:52 AM
C70CoupeMaui's Avatar
Wink Wheel Bearing Job
After viewing a wheel bearing fix for an Audi on youtube, it looks like a total nightmare, the kind that leaves your car in the driveway or towed.
It's time to call a mechanic on this one. Boy am I glad youtube is there, at least you get to size up the job before attempting. I figure $400 to $500 for the job. Well, it's my once-a-year big job, and I fully intend to let someone else lose their fingers and wreck their back instead of me.
Old Apr 15, 2009 | 01:09 AM
ICE's Avatar
ICE
Hey there what were the symptoms for your car to make you realize the wheels bearings had gone ?
Old Apr 15, 2009 | 01:40 AM
I went through this with my S70 years ago. The front wheel in question makes a whirring noise, like an unbalanced tire only worse. It's gone on for 500 miles, I'm taking it in pronto. The clock on the dash shows diSC, because the brake sensor, I believe, either picks up on the higher heat generated or the misalignment of the brake rotor. $400 to $500 repair. NOT worth even attempting.
Old Apr 15, 2009 | 08:16 PM
MoneypitC70's Avatar
Thumbs up
I did both front wheel bearings while I rebuilt the rest of the front end and it was pretty straight foward. Just a bit time consuming to disassemble/reassemble.
Old Apr 15, 2009 | 08:36 PM
The Job is pretty easy.
If you can do brakes and an axle it is a cake walk.
Old Apr 16, 2009 | 06:00 AM
ddub's Avatar
the clock on the dash shows disc because the rotary display selector switch is going bad...wiggle it a little bit or change your display selection and it will clear up for a while...
disc=disconnected in the computers mind
Old Apr 16, 2009 | 09:09 PM
Johnny Mullet's Avatar
Your C70 has a bearing hub unit that is way easier to replace than a regular press in style bearing.
Alyson
Dec 6, 2010 11:30 AM
nonsense619
Apr 24, 2009 06:47 PM
Viney
Jun 15, 2005 12:10 PM
RocknTommy
Apr 11, 2005 02:18 PM
julyccc
Nov 13, 2004 09:04 PM
