Where is the Speed Sensor Located
2001 C70 2.3 went into Limp Mode....had it towed home....engaged after unloading.....tried to take it around the block...went 75 yards and did i again....I will get a code reader with a tranny reader...just want to know where it's located for now....in case codes show that's the issue.....I know I need to flush it also...but other than that...I believe it's electrical...any other possibilities please let me know....
TIA
Karl
TIA
Karl
There is an Acceleration sensor located on the firewall, illustrated in Chilton 72302 manual, pg. 4-20. Calls for the removal of passenger side wiper arm. Vehicle speed sensor listed in Haynes manual 3573, pg. 12-7, doesn't have a speed sensor but function is provided by ABS wheel sensors, wiring connector located behind ABS module, 2 wires, black connector, fig. 7.1. FYI. These 2 manuals are real good to trouble shoot.
Still no update after a year Still saving for that OBDII reader ?
Might want to swing by autozone or oreilly and have them read it for you
Instructions on replacing speed sensor:
How To Replace Speedometer Sensor On Automatic Tranny? - FWD/AWD 1998 and Prior - Volvospeed Forums
Help Locateing '04 s80 Vehicle Speed Sensor
