Window cable is fine but not on "roller"
If u did it WITHOUT taking it out then you might have to...if you do have to take it out pay attention to the screws on the top that hold the mirror (NOT THE 3 UNDER THE PLASTIC COVER) but the 2 that hold it from moving back and forth...remember where it's located...then when you take the two bolts out from the bottom...it has a hex screw in the middle..(REMEMBER HOW MANY TURNS IT TAKE TO GET THEM OUT) if not you will have issues with proper closure and sealing...good luck!
mcadek
07-24-2015 01:08 AM
E43509
12-18-2009 09:15 AM
