01 keeps dying for no apparent reason
Old Mar 6, 2012 | 09:18 AM
nmikmik's Avatar
Default 01 keeps dying for no apparent reason
These cars keep giving and giving, aren't they...
My daughter's S40 with 135k gave her a scare about 6 month ago. It died on her when she tried starting the car after fairly short stay at the friend's house. I came there and started the car with no problems so I kind of dismissed that event as her inability to start the car
Now the frequency of "not starting" or starting ding has increased dramatically and it is a big concern for me now.
She says it starts up fine but then immediately dies, like it's running out of gas i.e. "slow death", then she pushes a little on the gas and starts the car with no problems. I am not sure, but fortunately or unfortunately, I can't pull any codes from the ECM and there is of course not CES on at this point. I can't even fathom a thought of going to the dealer and have them diagnose the problem, so I am asking here.
Is there anything I can try before I start replacing random parts like a crank sensor etc. ? Has anyone here experienced the same problem and what did they do to fix it?
Thanks!
Old Mar 8, 2012 | 10:49 AM
Hudini's Avatar
It's either the Idle Air Control motor or the Fuel Pressure Regulator. Unfortunately both are priced close to $200. The good news is both are super easy to fix yourself. I've replaced both on my 2001.
For me it was a long cranking time before the car would start. If I cracked the throttle a bit it would crank up and run as long as I held the throttle open a bit. I first replaced the IAC motor but this did not fix the issue. Then I read a thread describing the long cranking time to start and replaced the FPR which cured it for me.
xDread92x
Nov 7, 2014 01:25 PM
squidskull
Apr 16, 2014 04:43 PM
Daniel Sendelbach
Jan 11, 2014 07:29 PM
RGV10
Sep 8, 2011 07:26 AM
vtech22
Nov 18, 2010 03:19 PM
