'01 s40 1.9t-head gasket replacement
Old Feb 7, 2017 | 02:49 PM
dbrowns's Avatar
Default '01 s40 1.9t-head gasket replacement
brand new to forum format,never used one b4 and hopefully i'll get the responses I need. What I'm looking for is a step-by-step tutorial/video to enable me to change out a head gasket on my grandkid's '01 s40 1.9t. I'm sure there has got to beother posts that someone can direct me to. Will I need any specialty tools? Will be greatly appreciated
thanks
dbrowns
Old Feb 7, 2017 | 03:03 PM
Smith Volvo's Avatar
Banned
thanks
dbrowns
see attached pdf
File Type: pdf
Old Feb 7, 2017 | 06:02 PM
dbrowns's Avatar
thank you very much
Old Feb 8, 2017 | 05:41 AM
Hudini's Avatar
If you remove the CVVT gear from the exhaust cam then you will need a cam holder tool to reposition the gear.
Old Feb 8, 2017 | 11:15 AM
dbrowns's Avatar
Default cvvt gear
i am going to disassemble today, and I assume because the head is aluminum I will have to send in head to have it resurfaced. Does the cvvt gear have to come off to have this done? I was thinking of just sending complete head assembly in.
Old Feb 8, 2017 | 12:02 PM
Banned
You will have to remove the cam cover to get the head off - so its all going to come apart. You should leave the hub and gears on the cams. You can slide the new cam seals over the cams from the other end when yo put it back together
Old Feb 8, 2017 | 12:17 PM
dbrowns's Avatar
Default thanks
thanks, I'm sure I'll figure it out when I get to this point, and if not, I'll be back to here
Old Mar 16, 2017 | 08:52 AM
dbrowns's Avatar
finally got it done, but in reflection, I'm sure this would have been 10 times easier if I would have just pulled the motor out and done this procedure on an engine stand-FYI
Old Mar 19, 2017 | 02:46 PM
Hudini's Avatar
Good to hear you completed the job.
I agree with you about removing the engine. I did mine like you with the engine in the car. All bent over trying to move things out of the way so I can move other things. Pain in the back for sure. Took me about 4 days total to get everything in order.
pprice
Jan 8, 2016 06:05 AM
boxpin
Dec 20, 2015 05:08 AM
Reid
Feb 13, 2011 10:01 PM
ENDEE666
Nov 8, 2006 08:29 PM
johnnybravo
Engine & Internal
Apr 5, 2006 12:52 AM
