01 sunroof help
Old Jul 18, 2015 | 02:54 PM
costa993's Avatar
Default 01 sunroof help
Hey guys, I changed my sunroof glass as the old one was full of corosion around the seal and was leaking. I found one in excellent shape at the do it yourself junkyard. I removed the old glass, place the new one but seem to have a little bit of play in the back part of the sunroof if i push it up from the inside of the car. The front part is ok. I didnt use the original tracks, I used the ones from the new one. Also the wetherstrip on the new one one is not the same as the old one. The bolts are tight but the play is from the track. I'm sure there's something I didnt do, it doesnt seem to be leaking though as I flooded the roof with water.
Old Jul 20, 2015 | 08:57 AM
costa993's Avatar
Nobody has any ideas?
Old Jul 20, 2015 | 01:03 PM
TEEKAY's Avatar
Thought I replied to this last night. You "should" be able to loosen the torx with the sunroof open and adjust the resting position. It's either the front set or the rear set, not both so you can adjust the angle. I remember fiddlin with mine last year, but with minimal success. I might have used this post, I don't recall.
https://volvoforums.com/forum/volvo-...-closed-39491/
Do you still have the original tracks?
Old Jul 20, 2015 | 02:21 PM
costa993's Avatar
Does this look right?
jeffd
Aug 20, 2019 10:03 PM
msf7770
Jan 30, 2007 05:30 PM
xpiecemealx
Mar 13, 2006 09:58 PM
Sneill
Feb 24, 2006 08:00 AM
