02 S40 rattle
02 S40 rattle
My girlfriend's 02 S40 has developed a rattling noise coming from the front passenger side. It's pretty intermittent but I think it's been getting worse. It doesn't seem to be directly related to the suspension, although it only happens when the car is in motion. I've tried bouncing up and down on the bumper and pushing back and forth but can't seem to reproduce anything. Could this be something like a loose hood liner or should I keep focusing on the suspension?
RE: 02 S40 rattle
I believe I went with recommended, which was still the longest install of any software I've ever used. Is there anyway to get that dust boot off without taking the shock off the car? The sound definitely seems to be coming from that general area, but everything visible looks ok.
RE: 02 S40 rattle
No way to get the dust book off with out removing it. Also the upper breaing plate might be bad. I have looked up there before with a small mirror and seen them bad.
On Vadis I meant when you created the new user did you select all in there. If not then you might only have access to minor things.
Vadis is like 3 gigs in size.
