02 s40... will crank but wont start w/o starting fluid
Old 01-01-2014 | 05:49 PM
Ironranger14's Avatar
Default 02 s40... will crank but wont start w/o starting fluid
Have an 02 Volvo s40... Thing has been running great... started every morning during a week of -30 temps... the 2nd batch of -30 temps all hell broke lose... itll crank crank crank but no fire. if i spray a little starting fluid in the air intake, itll fire right up and idle fine and what not... i just changed the plugs cuz that was the least expensive thing i could think of at the moment. What could cause this issue??
Old 01-01-2014 | 06:02 PM
difflock54's Avatar
Probably a fuel pressure problem.
Especially if it starts with the starting spray.
Check your fuel pressure and the fuel pump function.
Old 01-01-2014 | 07:23 PM
Hudini's Avatar
+1, usually fuel pressure regulator. Check the pressure first.
Old 01-01-2014 | 09:46 PM
Thanks for the quick replies. after doing some tests to see if the injectors were getting any power, they wre not... i went and messed around with the key and ignition and it fired right up. i beleieve the anti theft for it is sticking in the ignition or something which makes the injectors to not fire... weird i guess
shai_kino
07-07-2014 02:54 PM
jquiding
02-17-2014 05:16 PM
Fern Schmidt
2001-2013 model year V70
08-13-2013 07:43 PM
datderboy216
05-22-2010 07:38 PM
rpsail7cs
09-25-2009 10:12 AM
