Parking lights don't work
Old Sep 25, 2013 | 08:23 PM
LP's40's Avatar
Default Parking lights don't work
I bought a 2000 s40 for my daughter, the latest problem is the parking lights don't work. All the other lights work, headlights, brake lights, signal, hazard and high beams. All the fuses are good, all the bulbs are good. I bought another, used headlight switch. The parking lights don't work. Is it the CEM? Anyone? Thanks.
Old Sep 26, 2013 | 12:08 AM
Hudini's Avatar
That would be my guess too, the CEM.
Old Sep 26, 2013 | 07:58 AM
What is a CEM? Maybe the relay is bad.
Old Sep 26, 2013 | 02:17 PM
LP's40's Avatar
I don't see a relay specifically for the parking lights, do they run off the headlight relay?
Old Sep 26, 2013 | 02:18 PM
LP's40's Avatar
CEM: Central Electronic Module. It seems to be the thing that craps out regularly.
Old Sep 30, 2013 | 04:17 PM
LP's40's Avatar
It was the CEM. Got one off eBay for $89. Took about 15 mins to install. The lights are on all the time now (when the car is running) but I'm not worried about it. I need to find the trick to turn them off. Thanks everyone for the input. JP
Old Oct 31, 2013 | 12:39 PM
80sGuy's Avatar
^^From what I understand, you can't turn off the headlights in position O unless you take it in to a Volvo dealer. I know it's annoying.
Old Oct 31, 2013 | 07:28 PM
Hudini's Avatar
I've been told there is a procedure for turning off the daytime running lights. It's in the owners manual. I have left mine alone though so I cannot verify.
Old Oct 31, 2013 | 07:36 PM
80sGuy's Avatar
As far as I know, Volvo dealers can turn off the 'headlights' in position O and leaving only the Daytime Running Lights on, but I doubt if anyone can do it by using the owner's manual. The dealers needed to hook up to their computers for software updates - similar to Audi cars using Vag-Com.
Old Oct 31, 2013 | 07:44 PM
Hudini's Avatar
Turn the headlight switch to the 'Parking' position.
Insert the ignition key and turn it to II
Pull the main beam leaver towards you
Turn the light switch to 0
Return the ignition key to off and remove it.
Can You Turn Off Daytime Running Lights? - Volvo Forum : Volvo Forums
Old Oct 31, 2013 | 07:47 PM
80sGuy's Avatar
Interesting. What if one wants to put it back like before, just repeat the same order?
Old Nov 2, 2013 | 08:40 PM
Hudini's Avatar
That would make sense but there is only one way to find out.....
Old Nov 29, 2013 | 10:45 AM
80sGuy's Avatar
This method doesn't work for my car.
Old Jan 2, 2014 | 04:28 AM
geyserfr's Avatar
Default Parking light fuse 10A
When I switch on my parking lights the 10A fuse blows immediately. The running lights stays on. Is this also a problem with the CEM? With the fuse blown my fog lights does not work.
Scott V
2001-2013 model year V70
Jul 21, 2013 02:28 PM
cyclekarl
May 8, 2009 11:32 PM
siuc_gator
Nov 3, 2008 04:28 PM
alicia1972
Jun 27, 2008 07:21 PM
act1292
Dec 1, 2007 07:47 AM
