2000 S40 volvo wont crank but has power
Old Feb 13, 2014 | 04:20 PM
jquiding's Avatar
Default 2000 S40 volvo wont crank but has power
I recently picked up a 2000 S40 Volvo and have some serious issues. The car seemed to be running fine. I stopped for gas and when I tried to start the car the starter would not engage. I wouldnt even try. I checked the fuses and replaced one that looked questionable that was labeled engine with no change. I pulled the starter and had it tested. Oriely's said it wouldn't respond at all. So I bought a new and installed it. It didn't make a difference. I have been searching the internet and haven't been able to find any information that describes an issue like this. So now my family and I are having some bigger issues about getting around (as I'm sure most people can relate).
I am in need of help and fast. I would appreciate any and all input. Thank you
Old Feb 13, 2014 | 04:48 PM
difflock54's Avatar
Check your battery leads thoroughly and the end terminals carefully for good connections.
Also test to ensure the starter, alternator/regulator are getting power okay.
Make sure the ground connection to the car bodywork is clean and secure.
Old Feb 13, 2014 | 04:54 PM
ibanez958's Avatar
is ur immobilizer light flashing when u crack?
Old Feb 13, 2014 | 08:44 PM
jquiding's Avatar
I'm just now becoming familiar with what the immobilizer is. I have owned many different vehicles and haven't ever heard of it until last night. The vehicle didn't come with any manuals of any kind. I read that It may be as easy as pressing the lock unlock buttons five times on the key faub. Is there any type of truth to that? Could it be that? I have already checked and cleaned all of the connections and and am going to use a reliable tester.
Thanks for the replies.
Old Feb 13, 2014 | 09:16 PM
jquiding's Avatar
There is no immobilizer light flashing.
Old Feb 15, 2014 | 05:07 AM
Hudini's Avatar
Does the car make a "click, click, click" sound when you turn the key to crank it?
Do the lights dim or does the car in any way signal that you have turned the key to crank it?
Have you tried putting the car in neutral instead of park while cranking it?
Old Feb 17, 2014 | 08:47 AM
phoenixrob's Avatar
I just had a problem similar to this not to long ago. My issue ended up being a bad fuel pump. One way to check is if its your fuel pump is to depressurize the system then crank several times. There is a valve on the fuel rail right before cylinder 1 injector. Grab a precision screwdriver and press down on the valve after removing the blue cap. If fuel rapidly comes out then it may be electrical, compression, or air. Hope this helps you.
Old Feb 17, 2014 | 04:16 PM
jquiding's Avatar
First off, Thank you for all the help. I took the ignition apart and cleaned up the tumblers and springs. It seemed that what appears to be grease started to harden up and wouldn't allow the tumblers to move freely. Which in turn wouldn't let the ignition turn 100%. Then I took the shifter apart (the lever would slightly stick intermittently almost an immeasurable amount) and cleaned it up and had to file some sticking points down.
I got it done last night and worked so far. We will see....
shai_kino
Jul 7, 2014 01:54 PM
Ironranger14
Jan 1, 2014 08:46 PM
woodlief
Jul 31, 2013 10:33 PM
kimsautodoctor
Jul 13, 2013 11:59 AM
playa7970
Sep 23, 2008 11:50 PM
