02 Volvo s40 turbo
Old Jun 29, 2012 | 06:05 PM
Chambless776's Avatar
Default 02 Volvo s40 turbo
My Volvo has been having issues within the past month with idling and slow driving, it seems as if the vehicle is not receiving enough gas because it tends to stall out when you stop at a light or intersection. Any ideas?
Old Jul 5, 2012 | 08:13 AM
Hudini's Avatar
I'd guess either Idle Air Control valve dirty/failed or fuel pressure regulator failed.
Old Jul 11, 2012 | 10:59 PM
VA2GXB's Avatar
Check your turbo control valve. I know, it seems like a long shot, but I unplugged mine to see if it would cure my turbo woes (turned out to be a mechanical linkage that came apart!) and my car would cut out at intersections. I'm guessing the vacuum system had been barfed up by the TCV being off?
L
Old Jul 13, 2012 | 10:24 PM
Aleks's Avatar
Sounds a lot like a failed fuel pressure regulator, as Hudini says. I just finished creating a guide to replacing it, if you want to give it a shot!
https://volvoforums.com/forum/volvo-...t-guide-64228/
Daniel Moreno
Jun 21, 2013 11:01 PM
1Gray760T
Nov 13, 2009 08:19 PM
Keith Tobberman
Oct 23, 2007 08:33 AM
danger
Oct 1, 2007 08:38 PM
alchu
Aug 23, 2005 02:42 PM
