03 S40 after market wheels
Old Feb 26, 2019 | 02:41 PM
Lone3wolf's Avatar
Default 03 S40 after market wheels
My 03 Volvo has a stock wheel that is 15'' x 6.5'' (or 6'' I'm not 100% sure) with a p195/60r15 tire. The after market wheels are 17'' x 7.5'' with a 225/45/r17 tire size. If I put a 225/40/r17 tire on the after market wheels will is damage my suspension or abs in a negative way? What would this change affect? Is it worth it?
Old Feb 26, 2019 | 06:26 PM
There won't be any issues assuming the wheels are the correct bolt pattern, offset and center bore. Check wheel-size.com for the recommended rim specs.
The only difference between the 225/45r17 and 225/40r17 tire is the rolling circumference of the /45 is a bit longer (ie tire is taller) by 1 or 2% so your speedo may change by 1 MPH. Are you sure about the 225/40r17 size - that's not very common where the 225/45417s are...
Old Feb 26, 2019 | 06:45 PM
Lone3wolf's Avatar
I used a tire comparison website and I changed the middle number until I found one that was closest to the size of my original tire. I'm assuming it should still fit the rims.
Old Feb 26, 2019 | 07:40 PM
tires should fit fine. My final comment was just to note that not all tire sizes are common and can be hard to source replacements in that exact size. you will find plenty of brands and styles in the 225/45r17 or a 215/45r17 size that will be a close match to the +2 size for the 195/60-15s. the 225/40r17 will work fine as well, but there's not many tire styles in that size.
JaredC466
Dec 9, 2017 02:56 PM
futbolfan15
Feb 27, 2010 10:06 PM
Spankjunkie
Jul 15, 2008 06:42 AM
Meglog
Aug 17, 2006 02:48 PM
lanciak69
Oct 9, 2005 02:51 AM
