03 volvo d40 1.9. Fans. No start.
Old Jul 27, 2018 | 07:47 AM
Barry51's Avatar
Default 03 volvo d40 1.9. Fans. No start.
Start when very cold. Cooling fan comes on for a few moments. Then no start. Cooling fans only work with a/c on after cold start. Changed coolant sensor(volvo) and thermostat.
let car run with coolant cap off to check for trapped air and all I got was antifreeze bubbling heavily out of bottle. Going to try again with a/c on so fans run.
Old Jul 27, 2018 | 04:07 PM
habbyguy's Avatar
The fans only come on when the engine is really pretty hot (at least the gas models - diesel could be different, I suppose). My V70 fans were set to come on at 105° C (220°F), for example. If you have a VIDA or other device (like the Torque app with a Bluetooth dongle) you could monitor your actual coolant temperature to see if the coolant is actually hot enough to command the fans on.
Old Aug 1, 2018 | 01:38 PM
pierremcalpine's Avatar
I wonder if your water pump impellers are shot and no longer circulating the coolant - when was the water pump last changed?
John Dooe
Engine & Internal
Jul 5, 2019 09:15 AM
Ekuva Jona
Mar 24, 2014 07:14 AM
Aglowmobile
Oct 16, 2012 09:57 AM
misspaularsmith
Dec 28, 2010 09:54 AM
Carbuff
Sep 14, 2005 08:41 PM
