2000 Volvo V70 Coolant or Water?
Old Oct 15, 2012 | 08:01 PM
Aglowmobile's Avatar
Default 2000 Volvo V70 Coolant or Water?
I noticed I had what seemed to be a puddle of water underneath where my coolant reservoir is. I first thought that it was coolant leaking but checked several times and it was definitely water. Is it normal for water to condensate from that area?
Old Oct 15, 2012 | 08:31 PM
If you run the AC, it will drain water out of the cabin. How is the coolant level when the car is COLD?
Old Oct 16, 2012 | 08:32 AM
Thanks for your welcoming. Makes sense. I turn up the heat on the way to work b/c its very cold in the bay area at 5:30 in the morning. Coolant level is like an inch and 1/2 above the minimum line when its cold. I wanted to add some yesterday but didn't have time. How full should it be when cold? Last time I took my car in they said my coolant ph was 9% and that I should get a flush to eliminate the acidity. I've also heard your supposed to use "Volvo coolant" but my friend who works in a shop says all the volvos he's ever seen come in with regular green coolant. Any thoughts on that?
Old Oct 16, 2012 | 09:57 AM
The level is fine as long as it's between the marks. I forget the name of the coolant type but there are one or two other brands of it.
HECTORPORTALUPPI
Feb 18, 2012 09:00 PM
ed schuler
1998-2000 model year V70
Aug 4, 2011 06:56 AM
mortonight
Jan 23, 2010 08:34 PM
s70_007
Dec 19, 2008 09:26 AM
flapper
Oct 22, 2007 05:56 PM
