07 s40 Brake failure no start
Old Jul 18, 2020 | 01:52 AM
Das_Harii's Avatar
Default 07 s40 Brake failure no start
Recent issue cropping up with this vehicle is while driving red dash text : Brake failure, please stop safely. Brakes still work, can still stop, and all that fun jazz. Park and turn the car off however, can't start the car. Clearing the codes (unrelated O2 sensor codes cause I'm a terrible car parent) and the vehicle will start right back up. Sometimes I can drive it for 3 days before this happens again, sometimes 4 minutes. Any advice is most likely to be appreciated.
D
Old Jul 18, 2020 | 02:58 PM
GerBeGurGya's Avatar
Things to check:
Brake pad thichness
Fluid level might be low
ABS sensor
Old Jul 18, 2020 | 08:55 PM
does the brake warning go away on the restart? See if you can find a code reader that can present ABS codes - there should be something stored (separate from the P codes for engine/transmission)
zerochills
Dec 29, 2024 06:55 AM
good1662
Dec 26, 2014 12:39 AM
MELINDABRENNAN
May 16, 2014 10:10 PM
crosby1
Aug 17, 2011 03:45 PM
powerwagon80
Dec 19, 2008 09:17 AM
