07 S40 Door Panel removal?
Old Aug 25, 2010 | 07:48 PM
jasonl's Avatar
Default 07 S40 Door Panel removal?
I have an 07 S40 with a sticky driver side window. I am assuming the window regulator track needs some grease. Anybody know how the interior door panel comes off? I don't see any screws, but it doesn't appear to just pull off either.... Any help?
Old Aug 25, 2010 | 08:44 PM
SVTfocusO3's Avatar
The inside of the pull handle where the window buttons, there is a black piece of plastic that must be removed, may want to use a pick, it would be where your palm would go if you pull the door. After that, pry up with plastic tool the whole console bezel, what ever color it is and remove the connector. Then, you will see 2 or 3 t-25 screws, remove those, and you are going to want to get a GOOD GRIP on the lower side of the panel and pull like a mother$#&%$#! and it should come off, but I am sure some of the black clips will stay, remove those with a suitable tool and install back on panel. Once off, remove the inner door panel connections and stuff.
Old Aug 26, 2010 | 07:11 AM
jasonl's Avatar
Ok I will try today....Thanks for the help
Old Aug 31, 2010 | 02:43 PM
SVTfocusO3's Avatar
Can we remove these advertisers from the forum, like the one above? waste of space.
sjp960
Nov 14, 2009 09:36 PM
redmenaceT6
Nov 16, 2008 08:28 AM
etype38
Aug 1, 2008 07:11 PM
air2fakie
Jan 17, 2008 04:47 PM
RedTurbo850
Jan 12, 2007 09:40 PM
