0w30 oil
RE: 0w30 oil
because you live in Texas (i.e. no cold winters or snow) the 0 w 30 is fine, although typically in 'normal' climates 0w30 is used as engine flush before putting full synthetic in it. Also, if you live in Texas, don't use a 10w grade of oil, you don't even have snow, a 5w grade full synthetic is the best oil for your engine, especially a 5w20 or 5w30 oil. Anything thicker and well, I mean you do havea turbo engine don't you? If not, just stick with either of those grades, or recommended grade in the owners manual.
