1.8 petrol (x reg) tapping noise
Old Sep 24, 2012 | 12:20 PM
TimToil's Avatar
Default 1.8 petrol (x reg) tapping noise
Hello
Having an issue with my S40's engine, seems like the valves are making a tapping sound on start up, it does seem to disappear occasionally but returns even when the engine is warm. I have added some hydrolic lifter additive to the oil but this has only made it worse.
What is the solution to this very annoying problem??
Help!
Old Sep 25, 2012 | 07:17 AM
Hudini's Avatar
Could it be an exhaust leak? When my 1.9L engine made tapping noises on start up it was a loose nut on the exhaust manifold studs. A stop nut fixed it from reoccurring.
With an overhead cam engine it's highly unusual for valve train noise. On mine the fuel injectors are louder than the cam and valves.
Old Sep 25, 2012 | 05:09 PM
TimToil's Avatar
Thanks for your reply but it's definitely not the exhaust.
Old Sep 25, 2012 | 07:24 PM
Hudini's Avatar
Do you have a mechanics stethoscope? Another method is a simple rubber hose held to your ear. Have someone start the car cold and try to pinpoint the tapping noise. The valve train mechanics are very straight forward. Cam - bucket tappet - valve stem. Mine did not have a method for adjustment other than replace the bucket tappet with a thicker one.
Have you a loss of power? Although rare it's possible a valve spring has broken and is rattling around. There is no room for anything to fall down under the tappet from above.
Xrious
Aug 4, 2021 09:34 AM
Baffled
1998-2000 model year V70
Aug 29, 2013 04:57 AM
fritoking
Sep 26, 2012 03:50 PM
stavrout
Sep 19, 2009 02:16 PM
Volvoman
Sep 25, 2003 11:26 PM
