105k reg maintenance light
Old Apr 29, 2014 | 05:51 PM
vnewby's Avatar
Default 105k reg maintenance light
reg maintenance light is on and im hearing about service inspection, timing belt replacement and aux belt replacement (aux belt only mentioned by a dealer). ive been calling to get quotes, all around $700-$800. also read that volvo says new timing belt at 120k but 105k is better. Can anyone simply advise what to do, my cup is overflowing right now
Also, any recommendations for Orange County Volvo mechanics would be great too
Thanks!!!
Old Apr 30, 2014 | 05:14 AM
ES6T's Avatar
What year S40?
Old May 3, 2014 | 05:26 AM
Hudini's Avatar
Your sig says 2006 so it is 120k miles. If Volvo says 120k then that is good enough for me. As long as the belt is not contaminated with oil.
Service light just means time for an oil and filter change.
I would not change the accessory drive belts until they fail but my car rarely leaves the local area so I'm fairly safe. If the belt driving the alternator fails then your car will run as long as the battery lasts. If you have the cash then have them changed when you change the oil and filter.
Old May 3, 2014 | 06:59 AM
ES6T's Avatar
Sorry, can't see sigs on the mobile version.
I would do the drive belts at the same time as the timing belt, unless they are in bad shape. I have seen more than a handful fray and get caught up in the timing cover and cause bent valves.
chef
Nov 7, 2009 10:05 PM
rodmodder
Nov 5, 2009 06:17 PM
kriflic
Aug 11, 2009 12:57 PM
S80Mama
Jan 21, 2009 09:25 PM
s80t6schcik
Mar 12, 2007 08:31 PM
